Permanent controller assignments?
Steve-o
Post by Steve-o »
Maybe I missed something, but is there a possibility to load the assigned controllers (e.g. assigned to masterkeyboard) automaticvally for each device. Example: you assign all knobs of MINIMAX to the midi controller values you need, saver them to your personalized file-> reload Minimax-> default controller values are loaded ??
Any idea anybody?
Regards, Steve
mr swim
Post by mr swim »
I think that the only way to do it is to save a preset - this SHOULD (no guarantees from this end . . . doesn't seem to work for the 1632 mixer anyway) save all your midi controller assignments (i think).
I'm sure someone else will be in a better position to help, but heh, might be a start if you're looking for a quick fix . . .
W
bosone
Post by bosone »
i found that sometimes not all the CC assigned are restored in this way.
