Logic and XP: No XTC!
Discuss Scope XTC mode.
jboeke
Post by jboeke »
Why oh why - if Iload XTCproject.pro and exit SFP - doesn't logic want to start up anymore? I really need to work in XTC mode!
Jasper
<font size=-1>[ This Message was edited by: jboeke on 2003-07-14 17:58 ]</font>
siberiansun
Post by siberiansun »
did you properly edit your xtcproject.pro?
try replacing your current .pro with this one:
http://www.planetz.com/forums/viewtopic ... forum=14&0
i use that one myself.
good luck!
zelimir
Post by zelimir »
hi jboeke
I cannot get XTC plugins either, although everything is prepared and done as i should be.
I gave up. Actually, working in SFP is much easier and "logical", you directly see what is connected where, you can combine synths, ASIO, wave devices, external analog inputs, huge gallery of effects to the same mixer.
Logis I use for sequencing ASIO software synths FM7, B4, PRO-52, then my MIDI keyboards, and finaly Creamware synthesizers.
I am 100% satisfied with this kind of setup.
jboeke
Post by jboeke »
Hi Zelimir
I know it makes the most sense to do so, but I sometimes miss automation control of CW effects, wich is a great feature of Logic I find.
I've heard in the meantime that installing an older version of SFP and then upgrade it is the only way.
Cheers
<font size=-1>[ This Message was edited by: jboeke on 2003-07-23 08:34 ]</font>
actually,the cw plugs need to be in logic's vstplugins folder and xtc must be enabled in the settings window of sfp.from there it should work.if not,then reinstall sfp over the old installation making sure that when the window askimg where to put xtc -plugs comes up that the vstplugins folder is specified.(it should be automatic)
Zer
Post by Zer »
You didn`t forget to close the pulsar app int the task panel, did you ??
felix o.
Post by felix o. »
for having xtc plug ins available you have to install first sfp driver only, second install logic and third install sfp software with xtc mode enabled.
