Moderators: valis , garyb
Nestor
Posts: 6690 Joined: Tue Mar 27, 2001 4:00 pm
Post
by Nestor » Sun Jul 06, 2003 9:25 pm
Which is the correct speed for my CPU?
Mine is Pentium 4 2.4B Northwood
Nestor
Post
by Nestor » Mon Jul 07, 2003 1:18 am
Everybody says different things, some tells you 80C*, while others tells you 69C*. The point is, how much hit can it stand overcloking it?
Immanuel
Posts: 3018 Joined: Thu Oct 25, 2001 4:00 pm
Post
by Immanuel » Mon Jul 07, 2003 7:41 am
Speed or heat Nestor?
Do not overclock. You are not ready for it yet. It should stay below 60 degrees IMO.
Nestor
Post
by Nestor » Mon Jul 07, 2003 9:19 am
Oh... Mama mia... of course HEAT, not SPEED, how did I end up saying speed...? No idea
<font size=-1>[ This Message was edited by: nestor on 2003-07-07 10:20 ]</font>
Nestor
Post
by Nestor » Mon Jul 07, 2003 9:22 am
BTW: Don't worry, I will not for the moment... I too know I'm not ready for it. This is for real geeks, isn't it?
I just wanted to know about it, cos I'm getting into BIOS and could see it's so "apparently" easy to do so.
Posts: 4743 Joined: Sat Jun 30, 2001 4:00 pm
Post
by at0m » Mon Jul 07, 2003 9:54 am
I don't think
this link is the Northwood, but it will give you a good idea. 71°C is the max operating temperature. Values of around 38-45°C are most common...
Nestor
Post
by Nestor » Mon Jul 07, 2003 8:54 pm
Mine at idle is running at about 40-44C*. Never pushed it yet, cos I coudn't even install XP yet.
Valium
Posts: 224 Joined: Mon Apr 09, 2001 4:00 pm
Post
by Valium » Tue Jul 08, 2003 12:48 pm
Max temperature for Northwood B cores is 75C. Remember that the p4 uses thermal throtling meaning that if a higher temp is reached it will keep working but it will slow the clockspeed down in order to decrease the outputted heat.
HTH
Greetz
Nestor
Post
by Nestor » Tue Jul 08, 2003 10:40 pm
NorthWood are very rather sensitive to heat, so we should not speed them much, I've read a lot about it, and there are too many bad experiencies. Beware.
siberiansun
Posts: 437 Joined: Tue Oct 01, 2002 4:00 pm
Post
by siberiansun » Wed Jul 09, 2003 9:14 am
how do you check the cpu heat?
arela
Posts: 858 Joined: Tue Aug 27, 2002 4:00 pm
Post
by arela » Wed Jul 09, 2003 12:13 pm
You'll probably find a utility on MB cd.
For ASUS P4PE its called PC Probe.
There are also a lot of freeware u can use.
Nestor
Post
by Nestor » Wed Jul 09, 2003 1:48 pm
My new MOBO checks it for me, I just go to the BIOS and can see the temperature of the MOBO, which is always about 16 to up to 20C*, and it shows you the CPU too.
