Best solution for ghosting ?
Spirit
Post by Spirit »
I do a lot of work on the web - collecting data, distributing data, visiting lots of sites etc. I have a "frontline" machine which does all the online work (P3 866 XP) but I find it's constantly being corrupted.
I have Norton and Spybot but every few months things just starts to degrade.
At the moment IE6 is driving me nuts. For no reason I can find it will simply stop loading a page and give the error message "not responding". Certain sites seem more liable to cause this than others, and certain streaming video files *always" cause an error.
I've tried sfc/scannow to check system files, loaded all the latest patches in the hope of overwriting any bugs, done a thorough system clean etc, but all to no effect.
So the real question is: "What's the easiest way to back up and restore?"
Here's what I'm looking at:
- A USB-2 card with an external drive. I'll ghost the image to a 40Gb external hard drive and reload every month or two (anyone have experience with that?). If it is plug n' play then perhaps I could use it to burn ghosts of each of my machines ?
- DVD burner. Ghost to DVD and reload that way (expensive...)
or...something else ? Any more options ?
I'd really appreciate any ideas or experience you might have since this issue is driving me nuts and I don't like having to do a complete reinstall from scratch every couple of months...
thanks
<font size=-1>[ This Message was edited by: Spirit on 2003-06-26 10:44 ]</font>
Micha
Post by Micha »
For this we use a second drive with a folder called images. Then we use Powerquest DriveImage 5 and copy the Partition to a file. We use the 2 diskettes, that you can create from the program cd. Norton Ghost also can do this.
Nestor
Post by Nestor »
How heavy are all the images toguether? I don't think they are very heavy cos you are talking about all the programs installed but no data with them... Am I right?
Spirit
Post by Spirit »
Good question... Maybe it could fit on a CD ? Anyone know how big a simple image using Ghost is ?
Nestor
Post by Nestor »
Many people talk about CDs as their recipient for images, but I have never done it myself, so I can't tell. What is logical is that only programs, well... it depends on what you have. For me, a CD would be perfectly enough...
bassdude
Post by bassdude »
I use a cd to ghost the image to. I don't use compression and I can make a bootable CD ghost image of my win2k plus music apps partition on a single CDR. But I had to do things like delete the swap file (it's on the same partition) before I burnt the image. This is not a big deal because windows just creates a new one when it restarts.
It's great because a full system restore is completed in about 15mins!
You can spread the image over serveral cd's if required.
Nestor
Post by Nestor »
Well now this is great... I think this will be my own solution as well... But which of all the programs available to do it would you recomend?
ChrisWerner
Post by ChrisWerner »
I use Drive Image, too. And had no problems with it. Knock Knock Knock.
Every 3month I make a new image and merge it to several CD´s. My C partition with CD Burner Software fits to one cd and can be recovered at once.
Then I can recover all other partitions but I needn´t it ,yet.
kimgr
Post by kimgr »
I can add a big "Yes" vote for Drive Image.
Been using it for years with no probs...
And the new version 7 can create the image from within XP !
Kim.
bassdude
Post by bassdude »
Well I use Norton Ghost. The only Norton software I like! Mind you it was originally Symantec I believe.
But isn't there a free piece of software that will let you do a similiar thing?
Nestor
Post by Nestor »
Well, but which is the best of them all?
Astral Fridge Magnet
Post by Astral Fridge Magnet »
Hi Nestor,
If it is not too late to suggest, I use Ghost by Symantec/Norton and it works brilliantly for me.
Regards
bassdude
Post by bassdude »
I don't think there is a "best of them all". Just pick one! Ghost has never failed for me. Toshiba are using it for the recovery disk that comes with their laptops.
Stubbe
Post by Stubbe »
Here's my setup for all it's worth :smile:
Been using Ghost for 3 years now, in a setup where I backup to a internal HD which I turn on (it's in a removable drivebay, activated and locked by key - you'll get the same effect with an USB2-drive).
The Ghost floppy disc goes in to the machine, which is turned on, and then I've written a small script that'll ghost all my partitions to the backup-HD.
This is done appr. 4 times a year, in between I backup important stuff to CD.
Have had to restore a couple of times, which have worked OK. Partition Magic does not like it, but it's easily cured, and the machine runs perfect afterwards.
BTW Spirit, have U tried programs that'll clean up your registration database ? I had problems similar to the ones U describe, and are now using Regcleaner with good result. Other programs will probably do the same.
Well, hope U get it fixed, that's all for my dime :wink:
Stubbe
