Yes, you use the 'Dyn Voices Of Parent'.
I usually use an IF module, and set it to send a 0 if you want it disabled, and a -1 if you want it to use the polyphony set on the Preset List (sending a 1 makes it monophonic, of course, which I will use for things like effects that come after the Poly 16 module).
<br>
Regards,
John Bowen
Switching devices off
Martin Lind
Budding Pulsarian
Posted: 2001-06-26 09:35
There have been some talk about switching devices off and unloading the DSP's - Why not use
the 'Dyn Voices Of Parent' modul??
'0' - Switching the device off and unloading the DSP's.
'1' - Guess what
anyway, i have a signal switch ex atom in my switches directory. it lets you specify whether it's a one in to many outs switch or many ins to one out switch. and it lets you choose how many is many
On 2001-07-01 09:44, spacef wrote:
no no, it does work inside inserts. may be put it inside the inside of the insert effect. i would even say it works perfectly
<font size=-1>[ This Message was edited by: spacef on 2001-07-01 09:46 ]</font>
in fact in the bigmixer'pulsar'
when you switch the inserts on/off the dsp meter doesn't change
now if you delete the audio input cable of these channel the inserts devices loaded are unload form dsp's !!!!!
then the switch on bigmixerV2 is just a bypass.....
about switching inserts off.
Yes may be you are right it is something that happens in the Big Mixer, i've heard about this before. But in an insert rack for ex, it seems to work fine .
