yesterday i´ve got some interesting news from the mess
1) xtc will be a software! you will not have to buy new cards-you can use it with your pI or pII cards you have. it allows the mode called XTC to use all effects or syhnths directly in your vst-compatible sequencing system.
BUT: note that you will have the latency of the audiocard for playing the instruments via midi... in the case of the fair-system in frankfurt that was 25ms at creamware! the cause seems to be: you are loosing the possibility of the ulli-settings which are only available in pulsarmode when you have the envoronment in backround (in xtc-mode the environment-projectwindow- is away!)... in xtc-mode you have no wiring possibility!
2) pulsar II srb will not get sold anymore... the new dsp-card is pulsar xtc. that´s changing!
advantage: user who don´t need the pulsarenvironment with extra ins and outs on that cards don´t have to use a complete card for the xtc-mode. they can buy an xtc-card, can use the dsps, the instruments and effects on that card in their seyuenving program!
3) we will get an update which will have a real "master reverb" which sounded real great at creamware... a REAL reverb... and some new effects which seemed to be from the scope platform... also delay which can do up to 4 sec!
4) all this information from creamware direct... but you know: i don´t give any warranty....
greetings and good luck!
t.
