XTC and Volkzampler plug-ins not in VST inst panel!!
Discuss Scope XTC mode.
MiXiT-G
Post by MiXiT-G »
Why isnt XTC mode detected in my cubase vst instrument panel?? niether is the volkzampler?
I closed scopeFP but i cant access XTC in Cubase VST/5
Should i re-install cubase or SFP? or do i need to specify the DIR for VST's?
There is a field for modules in SFP set/dir that is blank do i need to enter a DIR there?
yes,that's where to specify a dir.just reinstall over the first installation.it should work.(needs to be in cubase's vst plugins folder)
MiXiT-G
Post by MiXiT-G »
Thanks garyb it worked.
But for some reason Dynamics (compressors, gates)is not there...any idea?
no idea.i'd try again.if in xp,make sure to do the install logged in as administrator.you might also be able to transfer the files manually.not to be insulting by bringing up the obvious,but you don't have any antivirus stuff going on,do you?
MiXiT-G
Post by MiXiT-G »
Nothing like that XP is hardly running, iv'e tweaked it to every resistor.
Just seems strange that all but one plugin works...
i say it is best if you DO log in as administrator,when installing sfp........(you can't disable that!)
