<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-tag"></a>Type: Sample Looper<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar 3.x<BR> <a name="planetz-tag"></a>Requires: Modular 2<BR> _____________________________________<BR><BR> Did you ever had problems with samples that won't loop in the Sample osc.?
This Patch can load 4 samples and reloop each one on an own number of beats, according to the BPM clock set in the Clock module. The lenght of each loop is set in a Clock Divider used as gate source for each sample.
So, if you want a sample to loop after a bar, you must set 24/96 in it's Clock Divider (24/24 it's a quarter).
If you set a loop lenght that excedes the sample lenght, the sample will play only as it lasts, then wait the end of the loop to restart. this can be a nice compositional feature, as well as setting a loop lenght smaller than the sample, changing completely it's design.
If you also transpose the Osc's by octaves......you could use a single sample and have four totally different things playing together.
And best of all it's made to loop the samples that don't loop!
enjoy,  Alfonso.
 I found that clock divider's second out has a bug and the values are not correct. To fix the patch just load two more dividers, connect them exactly as the others, and dedicate a single divider for each sample.
<font size=-1>[ This Message was edited by: alfonso on 2003-06-26 04:52 ]</font><BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/mod ... Looper.gif" BORDER="0">
