I wonder if a set up like this will work.. can anyone confirm this?
I want to plug a muti in/out sound card (I have a Terratec in mind for the job...) and use it in conjuction with a Pulsar XTC.
Can I assume I can use the XTC DSPs to process audio coming into the terratech with the Pulsar XTC, as well as audio generated by the computer, and be able to generate audio (via Pulsar sintes) and route it all through the different outs of the Terratec?
This would be a powerful setup...
Thanx in advance for all the comments.
-Dilema-
						Question about Pulsar XTC
exactly this is the idea of XTC. But have a look on this forum, especially in the Scope developers folder, to look for the backside. TC Powercore is probably also a solution for you. This comes with great effects!! and I'm very sure that powerful synths will follow. And don't forget: 64 Bit knocks on our doors and then it's probably better to have everything as software and not to have software that is strictly bundled with a 32-bit card and at least outdated then.
Hope it helps
Micha
						Hope it helps
Micha
