<hr>
Hi there fellow Pulsarians,
Pulsar II doesn't work reliably on VIA chipset motherboards right?
WRONG!!
Here's how this sick little puppy convinced his Pulsar II card to run reliably on a MSI 694D Pro motherboard alongside a SCSI card and a Delta1010 audio card.
The MSI 694D Pro mobo uses the Apollo Pro 133a Chipset. When I first installed the Pulsar II card it would only run in the first 3 slots. It seemed fine until I pushed the DSP usage over 25%. Then I would be harrassed by "PCI-Master Overflow" messages. If I pushed the DSP to 75% I would get an error every 30 seconds or so. I had tried everything. BIOS settings, slot juggling, RAM & software tweaking.
Nothing seemed to help. In fact most BIOS changes made it worse.
Finally I remembered the utilities I was already using to tweak my RAM settings. This pair of utilities, called 'Wpcredit' and 'Wpcrset' allow you to alter the chipset registers themselves, much the same way the BIOS does.
I used these utilities to change 2 registers. These are:
"Arbitration Mechanism Priority"
changed from CPU/PCI to PCI, and
"PCI-Master Read Caching"
changed from disabled to enabled.
Either of these 2 settings on their own fixed the problem! I enabled both. After changing these registers I could run Nuendo at 75% CPU
plus PulsarII at 95% DSP (mostly reverbs). If I push the computer CPU any more than 75% windows becomes very sluggish.
I left the computer looping like this for 12 hrs without one error!!
Instructions on how to use these 2 utilities can be found at
http://viahardware.com/memtweakguide1.shtm
These instructions are for tweaking memory settings, but they will explain how to use the utilities. The utilities can be downloaded from
http://hp.vector.co.jp/authors/VA002374 ... nload.html
You will have to also get the correct WPCREDIT PCR Files for your motherboard chipset. The WPCRSET program can still be obtained at
http://ftp.vector.co.jp/pack/win95/hard ... crs120.exe
The registers I changed for Apollo Pro 133a Chipset were:
Register: 70 HEX: 44 (PCI-Master Read Chaching > ENABLED)
Register: 75 HEX: 21 (Arbitration Mechanism Priority > Change from CPU/PCI to PCI)
Remember EITHER of these changed registers fixed the problem on my motherboard. For different manufacturers and different VIA chipsets these register & HEX numbers may be different. You will have to use WPCREDIT to find the registers called 'PCI-Master Read Chaching' and 'Arbitration Mechanism Priority' and change them as required. You can change registers in WPCREDIT while windows is running, which makes tinkering very easy. Once found, you should enter these settings into WPCRSET, then they will be autoloaded every time windows boots.
I know this seems complicated. Truthfully this tweak ISN'T for the PC newbie. By changing the wrong registers you may even damage your motherboard (although unlikely). [...]
Besides, if you can work out the Pulsar environment you should be able to use these utilities.
By the way, the fact that changing 'Arbitration Mechanism Priority' from CPU/PCI to PCI fixes the problem tells me that this problem has more to do with the way the VIA chipset controls the PCI bus, rather than being a PCI BUS bandwidth problem. The PCI devices themselves obviously have a better idea of how to run the bus than the VIA chipset does.
I hope this can be of help to some of you using VIA chipset motherboards.
Your fellow Pulsarian, trying to make the road a little less rocky,
Spliffy.
reaktor@mailbox.as
<hr>
<i>so i hope that´s really THE solution, there was already some very positive feedback in the cw forum. it seems to work</i>
<i>Mo</i>
<font size=-1>[ This Message was edited by: Mo on 2001-06-20 17:27 ]</font>
