Logic & Pulsar beginners
If you´re using Logic and Pulsar you´ll come quickly to the point that you ask yourself: "Man I wanna have the total control about everything." It´s just that simple: Use the Bigmixer V2B and apply for each device and especially for the bigmixer a new sequencer midi source (make sure you´ve changed the driver setting to use at least 8 midi outs and ins. Connect the cables as you´re in need of, go to logic´s hyper editor twiggle draw a controller, playback the sequence in a cycle and switch to the pulsar window and apply the controller´s to as much knobs as you´re in need of. Sometimes the movements of the controllers are sounding "squary" , ´change the draw size in logic to void this. Now you´ve got the complete midi control about your project.
						If that was too short, simply try learning the basics of logic by referring to http://www.memi.com/makers/hwsw/tips/lo ... -tipps.zip
oh sorry... this file is in german....
<font size=-1>[ This Message was edited by: Zer on 2001-07-02 06:52 ]</font>
- paulrmartin
