Midi Controllers and zipper noise
- ElectronicaDub
Certain synth knobs aren't smoothed on Pulsar synths  If it was me, I wouldn't even bother with the Inferno and would go straight for the Saturn or UKNOW, both of which have the "smoothed" filter cutoff knobs (if my memory serves me correctly here)
It takes a tiny bit more DSP to smooth parameters and the developer has to do it.
You might try connecting up the MIDI output on the Pulsar synth module that's giving you troubles, to the Sequencer Destination and record the movements done with your mouse -- that MIGHT fix the problem, but I haven't tested it yet Something tells me that may not work though either.  Using another synth or an external filter like ZFilter might be your only option.
  If it was me, I wouldn't even bother with the Inferno and would go straight for the Saturn or UKNOW, both of which have the "smoothed" filter cutoff knobs (if my memory serves me correctly here)It takes a tiny bit more DSP to smooth parameters and the developer has to do it.
