16 bit or 24 bit in 48khz?
aMo
Post by aMo »
My Alesis Ai3 ADAT interface runs at 48khz in 24 bits..
But when I use 48khz in SFP, is it 16 bits or 24?
King of Snake
Post by King of Snake »
Someone correct me if I'm wrong but...
I'd say it depends on your material. You can work internally up to 32 bits (depending on your recording software) but whenever you go trough the ADAT interface it's a maximum of 24 bits.
if you're going to cd,i say work at 44.1k 24bit.
RedSun
Post by RedSun »
Creamware cards always work internally at 32bits. What you can select is the bit depth of the audio drivers you use(ASIO, WDM...) and the sampling rate.
RedSun .:.
ChrisWerner
Post by ChrisWerner »
24bit should give you enough headroom for a good mix. If you produce for CD, I agree with Gary, but be sure that you dither your stuff down to 16bit for the final CDmix.
I use no ADAT´s at the moment and run my Cubase/Pulsar duo in 44.1kHz 32bit/TrueTape.
