After you install Windows XP Service Pack 1 (SP1), your programs may take as much as ten times as long to start.
CAUSE
This problem may occur if the programs you run frequently allocate and deallocate large blocks of memory. Changes in Windows XP SP1 in the memory management system have caused this operation to take significantly longer than with pre-SP1 Windows XP.
RESOLUTION
A supported fix is now available from Microsoft, but it is only intended to correct the problem that is described in this article. Apply it only to computers that are experiencing this specific problem. This fix may receive additional testing. Therefore, if you are not severely affected by this problem, Microsoft recommends that you wait for the next Windows XP service pack that contains this fix.
To resolve this problem immediately, contact Microsoft Product Support Services to obtain the fix. For a complete list of Microsoft Product Support Services phone numbers and information about support costs, visit the following Microsoft Web site:
Microsoft.com
NOTE: In special cases, charges that are ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The typical support costs will apply to additional support questions and issues that do not qualify for the specific update in question.
The English version of this fix has the file attributes (or later) that are listed in the following table. The dates and times for these files are listed in coordinated universal time (UTC). When you view the file information, it is converted to local time. To find the difference between UTC and local time, use the Time Zone tab in the Date and Time tool in Control Panel.
Date Time Version Size File name
28-Feb-2003 14:05 5.1.2600.1177 654.336 Ntdll.dll
you didn't think I wouldn't have a link to this did you?
http://homepage.ntlworld.com/ahrk_2k/fi ... 86_ENU.exe
