<a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-file"></a><a href="http://www.planetz.com/Pulsar/files/mod ... .zip"><img src="/forums/images/listen_icon.gif" border="0" alt=" Sound Example"> Sound Example</a><BR> <a name="planetz-tag"></a>Type: Effect<BR> <a name="planetz-tag"></a>Pulsar Version: Pulsar All Versions Ok<BR> _____________________________________<BR><BR> I know it is impossible to remove vocals from a track.
but nevertheless try this device: it mixes the R channel with the inverted L channel and vice-versa, in order to completely tremove the center of the sound spectrum. then the result is mixed with the original sound processed thru a 48db lowpass filter at about 300-400 db, to add the bass and the kik.
it could be a useful device also to "study" for ex. guitar tracks, which are (ex. heavy distorted ones) usually recorded twice and mixed full panned. so that they not disappear after removing the central sounds.
let me know how it this experiment!!
BEWARE: you MUST have J9k INV, which is used as insert for inverting the signal.
I added a sound example
Listen to my pulsar gothic music at
http://alchemyoflife.cjb.net
<font size=-1>[ This Message was edited by: bosone on 2003-04-02 06:51 ]</font>
vocal remover!
- at0m
If J9k INV is used in your patch, it is saved inside and we don't need it on drive.BEWARE: you MUST have J9k INV, which is used as insert for inverting the signal.
To inverted a signal, you can also ring-modulate the original with Constant Val Bipolar to -64.
