Hi everybody, i slipped into some strange probs while creating the new Morpheus Patch for ModIII. Unfortunatly i couldn't get any help from CW so far so i ask here as well.
1.(and most important) Saved Presets are not restored properly after storing them. Most annyoing is that the multiSegnebt Env is totally scrambled. Other settings appear ok on the screen but are not set in the audio way (mostly Envelopes). Did anyone made similar experiences ?
2. I discovered that thechannels of the tempo delay don't run in sync. E.g set left to 1000 right to 500. Signal becomes async after 3-4 repetitions. If left is set to 977 it runs fine. That means on the other hand that the channels run async whenever external sync is on. After testing i noticed the same behaviour with the Modular2 shell.
Any help is appreciated!
Greets, STefan
