Yes,
works for me fine with standard unbalanced cable, but I would like to know what is the diferences betwen mixdowns from AES to AES and SPDIF to SPDIF (simply) Is the final mix of AES/EBU stronger than SPDIF??
Maybe my question was not like I mean but this is what I would like to know.
BTW, AES/EBU option for DDX3216 is 150 US$. But the price is not problem. I like to know if I get better mixes with AES option I'll buy it
AES/EBU again
stelibo
- Mr Arkadin
As a general rule SPDIF will go to AES, but there are often problems going the other way. Check http://www.rane.com/note149.html for a technical insight into the differences. Apart from the impedence difference there's also sub-bits that tell your equipment if the incoming data is SPDIF or AES, which can cause some older equipment to have a fit. If you're doing a lot of digital stuff back and forth I would recommend getting a conversion unit. There are cheapish ones available, as well as the nice, but quite expensive, CO3 http://www.m-audio.net/products/m-audio/co3a.php
- garyb
- Moderator
i don't think there is a lot of difference in the final sound between sp/dif and aes/ebu.the main difference is that since aes/ebu is balanced,it will drive longer distances and be less likely to incur errors from outside sources(radiation).also,a balanced signal is less likely to have ground issues related to the cold conductor also carrying ground(chassis and signal ground can be kept separate).
in most cases,6 of one,half dozen of the other....ultimately,a boy scout(be prepared)will opt for the greater reliability of aes/ebu even though it may never really be crucial.i use aes/ebu w/a hosa aes/ebu-sp/dif converter(cheap at $60) because my pulsar plus has aes/ebu and lots of devices use sp/dif.
stelibo
Doesn't mean that I can't get digital signal with +4dB with AES instead of unbalanced SPDIF -10dB. Maybe something wrong with me, maybe I can't understand something but I am live gig player too and using Dynacord Power Mate mixer with balanced XLR inputs is mutch stronger than unbalanced.On 2003-03-09 02:57, garyb wrote:
So in that way I like to say/ask that I think that wit AES will get +4dB remix and with SPDIF -10dB only??
Regards,
Bobi & KOMPAS band
BLUE production
Bobi & KOMPAS band
BLUE production
Grok
Because AES/EBU & SPDIF are digital coding, there is no influence of the balanced/unbalanced topic on the sound quality. AES/EBU & SPDIF are strictly identicals regarding the sound quality.
What balancing gives to AES/EBU is the capacity to use (very) long cables without degradation of the electric signal. That's it and that's all. The signal electric level hasn't any influence on the sound quality because it's only a digitally coded signal and not an analogue signal as with microphones cables; with analogues signals electric level has an importance for the sound quality, but it's not the same with digitally coded audio signals as SPDIF and AES/EBU...So don't make the confusion...
I know, it's confusing
Toujours l'Amour!
<font size=-1>[ This Message was edited by: Grok on 2003-03-10 04:59 ]</font>
Toujours l'Amour!
- garyb
- Moderator
stelibo
