cool your PC!
On a slightly different note....
here's a couple of links to pages that discuss PC sound-deadening techniques.
http://www.overclockers.com/tips454/
http://www.makeitsimple.com/projects/ca ... ndex.shtml
I've tried some of these techniques in my own studio PC and can attest to the fact that they really do work.
algorhythm
is there any fire hazard with this? I have seen this idea before, but was skeptical to put a cardboard box and foam so close to the PS . . .
Wow, we're back on. Was quite some job, took me 6 hrs to isolate two pc's and install Mixer, AMT8, Triton and S5000 into the rack. Looks a lot more compact now and handy to work with, so concentrated.
And the pc's running are much quiter!!
I glued this black 1/4" carpet mousse on every part of my case that was not a venting hole and not behind my mobo either. Put some foam in the front panel, closed unnecessary holes in the back (unused PCI, SCSI and RAID, serial ports)
My CPU temp has gone up about 10°C, to CPU=52°C and CPU2=56°C.
What should be my max operating temp? Where can i find info about that? I have dual PIII 1GHz system, on an Acorp 6A815EPD.
Using Sioft Sandra and BIOS as reference for temp, I don't have nor need extra temp sensor on my pc. Is there and app that will monitor temps like Sysmon monitors stuff?
Not worried about my old PII 400MHz, but rather about the dual PIII system that also contains 2 Creamware cards.
I'm not looking forward to install extra fans in my tower, cos they'll get the noise level back up, most of them.
Cheers,
atomic.
Cheers,
atomic.
http://www.cpuscorecard.com/cpuprices/ip3.htm contains some temp limits, but i do not want to limit 1°C lower than disintegration temp
Do CPU's get hotter when handling more load? I think I saw something like that, but I'm not sure.
so it might not be a good idea to leave DSP cards under heavy (90-100%) load for a longer period of time, either (when running a warm system- this will be no harm if you have a cool case)
Considdering cool casses are most allways hotter than room temperature, Generating more heat from Pulsar will make the case hotter and eventually the CPU too. However, I would be more concerned about the soundcard, as that is more expensive to replace. I realy do considder putting heatsinks on my DSPs. Atleast that would make then cooler - never a bad thing.
Immanuel
Immanuel
Yeah, be careful with the heat-issue boys !
Some way back there is threads to some who had troubles to use Pulsar @96KHz, and it turned out to be cured with better cooling.
I (sound)insulated my PC this summer and found out that my boards ran at 50+ °C!
After installation of an extra fan blowing directly onto the boards, they came down to below 30°C.
Never had a heat-related problem (I think), but I can't help to wonder if the lifespan of my boards have been reduced ???
Just my 2 cents worth
Cheers
Stubbe
Cheers
Stubbe
also keep in mind a 120mm fan under volted to 7v or even 5v will turn very quietly and push as much air as an 80mm fan.
bigger fan always better, or 2x 80mm fans at 7v instead of 1 at full voltage will still be quieter.
if you have an amd with a "screamer" fan on it you can get an 80mm to 60mm fan adapter to use a bigger quieter fan on your cpu
<font size=-1>[ This Message was edited by: defex on 2002-03-04 08:26 ]</font>
A very BIG cooling solution:
http://www.dansdata.com/hx45fan.htm
And here for CPU cooling:
http://www.dansdata.com/coolers.htm
i do not know if this is a good store
http://www.overclock.co.uk/moreinfo.php?id=464
fan adapters in the uk. and pretty cheap.
