Drummers
spacef
Post by spacef »
I just wanted to find out if there are any drummers who use a creamware hardware in a drum setup (electronic drums for ex). I would be glad to hear experiences from you... if any :smile:
not a drummer,but i've used esd8 and esd16 and sds as sound sources w/hart drum pads several times.worked like any other synth....
spacef
Post by spacef »
that sounds cool :smile: ...
(I wasn't expecting many real drummers working intensively on Pulsar anyway .... )
no one else ?
Nikibuzz
Post by Nikibuzz »
I'm a real drummer and I use Pulsar exclusively with my midi kit and the sts 5000
spacef
Post by spacef »
mm, so I guess it works very fine, like a keyboard.... I was looking for comments on "expressivity" but it's only a matter of programmation. I asked because I have a friend who is a drummer, i want to connect him to my setup... (modulars must be fun....).
alfonso
Post by alfonso »
hi spacef,
there are some cool modulars for drummers imo...
and not only midi, but audio too....
send the drums signal (from mics) to these modulars, to add to the original sound or substitute:
http://www.planetz.com/forums/viewtopic ... forum=15&0
if you have mod3,
or:
for mod2.
nice for sending a snare, or single sounds another mod2:
http://www.planetz.com/forums/viewtopic ... forum=15&6
those are from mine....i suggest them as i know them :smile:
ciao, and let us know what does your friend think...
Jngaelin
Post by Jngaelin »
I use the STS3000 for to play.
I have allways had a synk problem with the SDS.
And i have tried to correct it by channging the ULLI to get a lower latency...but it doesent seem to get the problem to go away.
Maybye it's just me....
Well anyway.
I have used triggering mikrofones on my frinds aqoustic drums and that has worked well together with the STS3000 and i gues it would be even better with the STS4000 or 5000.
Good luck :grin:
Best RRRegards Jngaelin
wavelength
Post by wavelength »
you guys might like to try my "drum rep", on my shareware page (at the bottom). it was designed to replace a gated audio signal with a sample, perfect for drum-sound replacement + it works with a regular mic.
http://www.track0.com/wavelength/shareware.htm
cheers
stephen
spacef
Post by spacef »
that sounds nice
spacef
Post by spacef »
But it's more a remix tool for me (audio). My friend has to be captured in midi above all :smile:. There can also be samples, synths, modulars etc that can be triggered.
In fact may be i was looking for bad experiences, because i don't know much about drums, how electronic drums / triggers works in relation to triggering samplers/synth, but apparently it works fine.
