16 ch through 2 adat ports?
kiminet
Post by kiminet »
Thanks for responding
To be more specific in my question:Can I record 16 ch through 2 adat ports?I tried but it didn´t work.
Kim
darkrezin
Post by darkrezin »
I have never tried this (the most channels I've had to record simultaneously is 6) but I do not see why it should not work, if you set up a 16-channel ASIO destination and ensure all channels go to separate tracks in your sequencer. I'll try it out a bit later to test.
peace
yes you can.....(or i can)
Grok
Post by Grok »
It should be working at 24 bit 48 kHz
For 96 kHz you need Pulsar 2 and SMUX, 8 channels on 2 ADAT ports
Toujours l'Amour!
Jngaelin
Post by Jngaelin »
Works fine (for me) :grin:
kiminet
Post by kiminet »
I have Pulsar 1 and it simply won´t funktion with 16 ch rec though adat.The adatport that I don´t slave to is distorted.
It might be possible on Pulsar 2 or scope.
Kim
Grok
Post by Grok »
Kim
This should be possible with your Pulsar 1.
Conclusion: there is a problem with your setup.
So: check your setup.
Toujours l'Amour!
<font size=-1>[ This Message was edited by: Grok on 2003-02-23 20:59 ]</font>
kiminet
Post by kiminet »
Now it works.It was a digi sync. problem.
I bought a wordclock cable and slaved everything to one unit.
Kim
