loaded up my Ultimate Piano programme (from EastWest, Akai), gain seems really wimpy. I'm still mastering this software, and there seems to be several different places one can affect gain.
What's the best way to set these to get the most signal out of a sample, without clipping?
also, don't quite understand the velocity modulation settings. I have my keyboard controller set up so it outputs note-on velocities over a fairly wide range (around 40 up to 127) but the gain response out of the sampler seems pretty narrow. Is there some control or setting I'm overlooking?
TIA
wimpy gain in STS3000
marcuspocus
Marcus got that one, I had that problem too when I first got the STS4000, there are a few places to change the loudness, Global, per Program, and per Keygroup
Remember to check each of these when you have volume problems... Once you have the global loudness up higher, I bet the Velocity "narrowness" goes away.
<font size=-1>[ This Message was edited by: subhuman on 2001-06-12 08:36 ]</font>
