Pulsar & Audiophile
xandertreffers
Post by xandertreffers »
Hhheelllooooo!
I have a Pulsar (I), just started working with it and I am very happy with the card...Now I still have some old cards left and I wonder whether there is still a use for them...
I work with Logic on a P4, 2.4 gHz with 1 gig of DDR memory...
Right now I am using the Pulsar both for it's own plugins as well as for the ASIO stuff in Logic...
Would it be useful to use the Audiophile for Logic?...At first glance I thought that VST plugins sounded better over the Pulsar though...
If I would add the GigaSampler to the setup, would it be usefull to run the GigaSampler over the Audiophile card, or better over the Pulsar?...
To make it short: is there a way that I can still use the Audiophile card or not?
Tttthhhaaaaannnkkksss,
Xander
spoimala
Post by spoimala »
I don't see any reason to use Audiophile with Pulsar.
The more cards you have, the more likely you are about to have problems. And I think Pulsar does everything what audiophile does.
kimgr
Post by kimgr »
The only reason to use anything else besides Pulsar is if you want to run two Asio programs at the same time...
Besides my two Scopecards I have a Digi001, connected to Scope via Adat and sp-dif, so I can stream 10 seperate Asio outputs from another program into SFP. (Usually Acid.)
Kim.
