I have never used the XTC mode of Pulsar, so yesterday I thought I should give it a try. The problem is that I could not make it work very well, because there must be some connection wrong/missing in the XTCProject.pro (plz have a look at http://www.geocities.com/rodos1979/pulsar.html ). Furthermore, I could not find in any place these XTC menus that appear in the SFP Manual in the XTC Mode.
When I pressed in Cubase the Direct Button, I received the following message + no sound: (lets say I loaded the BlueSynth)
"Cannot make connection: pads Bluesynth.Out and Add 64L.In02 are incompatible and no appropriate converter is available" and then the same message with Add 64R.In02
What is the difference between the Direct button flashing blue, green or not flashing at all? What can I do to avoid this message?
Could you please upload a picture of how I should setup the XTCProject so that it works fine?
Thank you
<font size=-1>[ This Message was edited by: rodos1979 on 2003-02-08 06:11 ]</font>
<font size=-1>[ This Message was edited by: rodos1979 on 2003-02-08 06:12 ]</font>
