I have a VIA KT133 chipset and a AMD700. If you experience, like i did, frequent system crashes, try to cool your CPU.
my system works much well now!
for AMD user
CPU cooling is essential nowadays, especially for AMD cpus.
I even read about lowering the vcore in the BIOS causing a more stable system.
Also use termal paste between the heatsink & the cpu to have the heat dissipated.
If you have a via kt133 chipset, also make sure you do have the latest via 4-in-1 drivers!
Zork
[corrected a mistake]
<font size=-1>[ This Message was edited by: Zork on 2001-06-10 07:24 ]</font>
Zork
algorhythm
algorhythm
i was thinking of o-clocking this one a bit (if possible on cusl2-c). there is enough arctic silver for MANY applications in one tube. i will be getting athlon(s) in the fall if the nvidia nforce is as good in reality as on paper, and these run hot, and will use arctic silver on them. also, with better heat transfer, i can use a lower fan speed = less noise. basically, the arctic silver was only a bit more, and is more efficient. it is cool, get it?
