Hello , can u explain me what is the purpose of the audio to midi delay?
i 'm using cubase to monitor all the pulsar devices + vst instruments - how do i know if the devices are in sync without judge it by the ear?
does the latensy incriese while adding effects or using different devices (example does a big modular 2 patch has bigger latensy than a small dev?
thanx in advance...
Cubase Audio to midi delay
algorhythm
- AudioIrony
I have also discovered that working without a mixer in Pulsar and using 7ms ULLI causes problems with VST instruments, one in particular refuses to trigger at all. Not that I ever really used the big mixer, I always used the DynaMixer and then recorded the Pulsar output to audio tracks and applied effects in VST. Going back to that way of working now.
<font size=-1>[ This Message was edited by: blgrace on 2001-06-12 15:51 ]</font>
