For months I was only able to run Pulsar software 2.01 on my G3/500 running MacOS 9.1.
The first advice I got from Creamware was to downgrade back to Mac OS 9.04 as it was reported that *some* Mac-Users were having trouble after updating. I decided at first I would do a clean install of Pulsar on a fresh 9.1 system... this didn't work... Eventually I had to bite the bullet and go back to Mac OS 9.04.
*The following I worked out for myself*
1. Get rid of Action Utilities if you're using it or disable it in your start-up set.
2. Get rid of StartupDoubler if you're using it.
3. Don't index the drive that the Pulsar software is on.
I've now been able to run Pulsar 2.041 on this system flawlessly without a single crash so far. Hope it helps someone who is stuck using 2.01
All th best
