this is a project i've been working on as a substitute to XTC mode.
as you can see i've inserted some useful (imo)efx between various asio sources and destinations.
to use the SFP reverbs and delay in logic i've routed three buses:
bus 1 out 3-4, bus 2 out 5-6 and bus 3 out
7-8 and let the signal back in again thru three aux channels set on input 9-10, 11-12, 13-14.
this works great BUT!!
no SOLO on these auxchannels is possible! it's dead quiet.
as you see i also set up the SPL attacker in logics´ out 9-10, in 15-16 via auxchannel and when i wanna solo that perticular auxchannel i hear nothing.
the ez synt and the lightwave on the other hand, also monitored via aux are solo-able....(!)
i hope you see what i mean.. it's probably not possible to solo these channels but if it is... man, this would actually be an ideal setup for me.
so please get those grey cells in your head working and help a deep frozen swede
 <BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.planetz.com/Pulsar/files/pro ... roject.JPG" BORDER="0">
