replace your existing XTCProject.pro with this one.
XTCProject.pro will be found under SFPAppXTCApp
explanation:
in logic you will now have 4 inputs and 2 outs.
input 1-2 would be everything logic lets out... audioinstruments, audio, efx... well everything in logic. i use in 1-2 when bouncing audioinst to audio or want to "attach" a bunch of efx to an existing track.
input 3-4 is used as an input for external equipment. in my case "luna analog source".
the asio2-32 source 64/asio2 dest seems to work best.
don't forget to turn off SFP to get in the right XTC mood
let me know if it works for you as well
Good luck!!
<font size=-1>[ This Message was edited by: siberiansun on 2003-01-07 17:02 ]</font>
