24 bit recording in Soundforge problem
King of Snake
Post by King of Snake »
Hey people, I've got a pretty strange problem here. When I try to record a file at 24 bit resolution (with 24 bit wave source & dest modules loaded in SFP) Soundforge (6.b) always seems to be getting a mega-loud signal, it all the way in the red when I set monitoring on in the recording dialog, even when there's no signal at all coming from SFP. I don't have this problem using 16 bit modules.
What do you think it could be?
rodos1979
Post by rodos1979 »
Hello! :smile:
I ve got exactly the same problem and behaviour in SFP and SoundForge. Furthermore, when I record using the simple "Wave Source & Dest" modules I get a lot of clicks and pops, which I do not get when I record in Wavelab (using the same modules).
Thank you :smile:
martone
Post by martone »
Hello Guys from canada
Did either of you ever fix your problems because I am having the exact same ones!
dellai
Post by dellai »
Hello all, I have had the same problem a few days ago. If your running SX and try to record in Soundforge, try to set SX on 30fps and do this in Soundforge as well. I think its a sync problem in the newer version of soundforge, but I am not sure. :sad:
It helped me a lot, might be the same solution for you people.
