Hope some kind soul can help a newbie.
I want to run the output of my SBLive Platinum into my Pulsar 2 Plus mixer.  I tried using the Soundcard Source modules but it didn't work.
Now I am thinking of running my Live Drive's coaxial SPDIF out into my pulsar.  But where to?  The AES/EBU input, or the ADAT input?  I don't seem to have SPDIF inputs on Pulsar.  Do I need some kind of a converter? (I'm looking for a really cheap solution to my problem!)
<font size=-1>[ This Message was edited by: gregartemides on 2002-12-05 09:51 ]</font>
						connect output from an SBLive Platinum to Pulsar Plus
				snoopy4ever
Wellcome to Planet-Z.
Look.. I have a Sblive connected to my pulsarII classic, I just plugged the SP/DIF out of the SB to the SP/DIF in of my Pulsar, and voilá, just connect the spdif source to your mixer and there you go.
From your description I guess you have the PulsarII plus, I think you'll have to use a XLR to RCA convertor cable, those are pretty cheap and it will work ok.
So I see no reason for you to have problems with this setup. Hope this helps
Snoopy
<font size=-1>[ This Message was edited by: snoopy4ever on 2002-12-05 10:41 ]</font>
Snoopy
