Silly question...
rodos1979
Post by rodos1979 »
Hello! :smile:
I know this is a silly question, so I kindly ask you to forgive my ignorance...
Which is the difference between a 'Classic' Pulsar and a 'Plus'. I know the Plus has XLRs (balanced connections and AES/EBU istead of SPDIF)
I mean if on my 'classic' Pulsar I connect the I/O bunch of connections (I dont know which is its formal name) of a Pulsar 'Plus' does that make my Pulsar a Pulsar 'Plus'? Or there are differencies on the cards themselves?
Thank you :smile:
EarlyFirst
Post by EarlyFirst »
If your card has the XLR+Adat it's a plus if it has the RCA + adat it's a Classic
But if your card has the RCA with Zlink It's a Zlink card
wayne
Post by wayne »
balanced plus, unbalanced classic
spoimala
Post by spoimala »
rodos1979, yes, the cards itself are similar, only the I/O possibilities are different.
<pre>
CLASSIC:
unbalanced analog RCA
digital SPDIF
2xADAT
PLUS:
balanced analog XLR
digital AES/EBU
2xADAT
</pre>
<font size=-1>[ This Message was edited by: spoimala on 2002-12-03 05:09 ]</font>
On 2002-12-02 18:28, rodos1979 wrote:
...I mean if on my 'classic' Pulsar I connect the I/O bunch of connections ... of a Pulsar 'Plus' does that make my Pulsar a Pulsar 'Plus'?
the original question was if the simple exchange of the cable-whip (?) would 'upgrade' the card to the 'Plus' version.
The Pulsar One doesn't have an extension connector and it be rather strange if the complete board layout would be different just for balanced IOs.
A reasonable assumption in todays business...
rodos1979
Post by rodos1979 »
Hello! :smile:
Thank you for replying. However, only Astroman and Spoimala seem to have understood my question but I am not sure if myself have understood the answer! :roll:
Astroman, so that means a YES? (i.e. I can "upgrade" my Pulsar1 to a "plus" version simply by exchanging the cable whip?)
Thank you :smile:
P.S. Forgive my English, which leads sometimes to misunderstandings :smile:
<font size=-1>[ This Message was edited by: rodos1979 on 2002-12-04 19:58 ]</font>
i would say that the answer is probably "no",because the issue is not only balanced and unbalanced connections,but also level.the plus is pro +4db ins and outs.the classic is -20db.
my guess, too. There are 2 pairs of unused solder pads for smd parts near the rear cable connector of the Pulsar One, so it's obviously more than just the cable.
