celmo's x machine vs sharc one
marcuspocus
I have the Celmo X-Machine, unfortunatly, i don't have the sharc one...
So, i can talk about X-Machine... It is very efficient, low on DSP (with a DSP saving feature when used in mono), and complete... My old Shure SM58 sound a complete different new mic if i want to, or my guitar can have a subtle compression and limiter just before recording stage...
Pretty good... I see it as a channel strip that can take it all... There is parametric EQ, shelving EQ, limiter, compressor, SubBass Booster(this is cool, i can make my mic sound like a radio guy with the big voice
) , deesser.
You can also make different routing for filter section, and with it's two kind of input (line input and instrument input), the later give you enormous gain if needed...
It come with a bunch of different presets, and also Ken has made a small collection of some 'extreme' one.
Personnaly, the mic is always going thru it, it add to much for not using it.
Ho, also, since it is so cheap (80$) you can have both if you're not sure!
<font size=-1>[ This Message was edited by: marcuspocus on 2002-11-15 14:46 ]</font>
bosone
marcuspocus
- kensuguro
marcuspocus
Yes they work, i had a couple of adjustments to do for my taste, but they here ok. Like usual, all preset are just starting point.
Anyway, they where pretty helpfull at first, not that easy to understand all those concepts stuffed into one device.
I think you did them with a Shure beta smething hein? That's probably why they where so close to my mic
- kensuguro
spiderman
