This is the test to find out if you're:
1 The strong dominant type
2 The er-um, I not sure type
3 Or the complete neurotic paranoid type.
When you've finished your Pulsating for the day and you save your work, you take one last look at your screen, with its lovely symmetrical modules and cable connections, and press the close button;
Now, when you see the 'do you want to save' box, this is where the psychology comes in:
If you press no, then you must be the strong, silent type. Always making quick decisive decisions.
If you press yes, then you must be a 'um, well, er, maybe I will, maybe I won't' type of person.
And, if you see the box and go into a blind panic, thinking that you might have changed a setting between pressing the save and close buttons and then quickly press cancel, (in fact you spend three hours pressing save, close, cancel until you ring a friend to come 'round and shut down Pulsar for you), then I'm afraid you are a completle paranoid wreck!
(and I'm avaiable for counselling)
Dr. Robert Funkenstein (Bsc. Camb.)
<font size=-1>[ This Message was edited by: Robert on 2002-10-19 20:26 ]</font>
						The Pulsar psychology test
