XP doesn't let refresh rate to be set?
spoimala
Post by spoimala »
I'm so desperate that I cheapen to ask this here...
I just installed Win XP (because of Scope installation, which was such a story, you wanna hear? Am I the only one who needed screwdivers, clipper, claw, hammer, drill and violence to install a SCOPE card???) but I can't set my refresh rate. Or actually, I can set it, but it won't be set. All I get is 60hz. Not so nice.
Yes, I've installed newest drivers for card (ATI Radeon VE). Yes, I have set proper (well, not proper for a DAW, only 15", but..)monitor (Nokia 449Xa). I can select from the list of refresh rates 85Hz, but monitor (and my eyes) says it is getting only 60Hz. Why?
spoimala
Post by spoimala »
In case someone will had the same problem:
It is not enough to install the latest drivers, you also have to install latest "Ati control panel" and then Display Properties->Settings-Advanced will have some new tabs. Choose Displays -> Monitor and change monitor attributes according to your setup. Voilá!
DJATWORK
Post by DJATWORK »
I have the same card (ATI VE) and I´d like to get the DRIVERS without the software (control panel and that).
Cna you tell me how did you get that?
in the downloads page I can only get a ".exe" that installs everything, not only the driver.
THANKS!!
DJATWORK!
Uninstall the drivers and get XP's or Win Update drivers? That's how I work w Matrox G450...
<font size=-1>[ This Message was edited by: at0mic on 2002-10-19 14:19 ]</font>
Chill69
Post by Chill69 »
Interesting phenomenom, all original installations of XP have this issue. It is most prevailent in gaming, as that was what called it to attention in the first place. Microsoft for some reason locks the H refresh at 60Hz whenever a certain DirectX call is made at full screen, if you leave it in windowed mode, there is no change to the refresh rate. I have a feeling the Scope interface is being plagued by the same issues game developers are having. There are some solutions to this however -
1) Download and install SP1 for Windows XP, this will fix any issues with the refresh rate problems.
or
2) Check with your video card manufacture's drivers and find an updated one that will skirt the issues for XP. I know that ATI, Nvidia, and a beta Voodoo driver exsist and all will solve the problems.
Chris
spoimala
Post by spoimala »
DJATWORK, Do you really want drivers without control panel? You will stick with 60hz then. But if you want, this page has drivers and control panel separately :
http://mirror.ati.com/support/products/ ... ivers.html
DJATWORK
Post by DJATWORK »
Thank you very match spoimal!!!
I´d like to try them, because that control pannel suchs for me. I hate those "color controls" and things like that, wich I would never use.
I have a dual display setup, do you know if its possible to set the desktop to both monitors only with the driver?
thanks!
DJATWORK
spoimala
Post by spoimala »
Yes, you can have dual display with only drivers. But I bet you'll have refresh rate of only 60Hz... which of course doesn't matter if you have two LCD displays...
DJATWORK
Post by DJATWORK »
Unfortunally its not my case... I own 2 17" screens, now adays, I have 1 X 17" and 1X 14" waiting to the guaranty replacement for a samsung 750S...It had burned...
DJATWORK
Post by DJATWORK »
I Forgot...
Could you disable the Bus MAstering with your ATI card?
