Site running slow
- John Cooper
 - Moderator
I've noticed the site is running very slow this morning, and is giving occasional error 408/409 "resource usage" errors.  The ISP says the site is being throttled due to excessive usage.  I'm trying to figure out the problem -- they imply the limit of 180mb/hour is being exceeded, which I find VERY surprising, as planetz's daily average is about 350mb/day!!
Is somebody downloading every file on the site, over a high-speed link, or something??
Is the site under attack, or the target of an mp3 spider or something? Maybe I need to add some code to the forums to prevent abuse?
Or maybe the ISP is incorrect. I've entered a request for investigation with them, so we'll see...
Frustrating!!
-John
Frustrating!!
-John
- kensuguro
The 408 error comes up much more than before.. strangely.  It seems to go on and off.  As in, it's either very fast (normal), or I get 408 errors.  Kind of strange cuz if it's with the traffic, it shouldn't be that obrupt of a change.  Could be something more than just "traffic".  Hope things get figured out.
						I've noticed it too - in fact I was gonna post a message about it a few days ago. Actually, I've noticed it ever since you changed servers (or host services). It hasn't been as fast as in the past.
I check in a few times during the day and it seems worse during the day. Sometimes, can't get on at all.
- John Cooper
 - Moderator
- John Cooper
 - Moderator
Aha, ok, I think I have a solution...
If I move all the downloadable files into a separate subdomain (like downloads.planetz.com), then the bandwidth on that sub-domain is tracked separately from the rest of the site. So if people are downloading tons of files, those will only cause the download subdomain to be throttled, while the forums continue to run smoothly. I hope!
I'll give a progress report here later.
-John
-John
- Nestor
I have noticed I couldn’t open the forum, but just for a while, 30 or 40 minutes perhaps then everything works correctly. Right now it’s working fine.
As some of you said here, I too have experienced a real down on the speed of my connection, from about 25 days on. Definitely, something huge is going on…
I have lately had many virus problems on my system, it’s was real scary… Some stupid people started sending all around the world the “yaha W32” kind of viruses and other kind of W32 which are very dangerous cos they can sometimes pass through your Firewalls as well as through certain antivirus software.
If you use Outlook as your mail option, you’d better go to Symantec to download the Bugbear remover; it’s a little program to remove the W32 Bugbear virus.
Take note of that: I’ve got 15 viruses and 2 Trojans in my computer… so guys, you’d better take as much care as possible nowadays, there is a lot going on the Net. I think they were send from Germany and Sweden, cos of the language, but who knows… Fortunately I could remove them all and my system is clean.
- John Cooper
 - Moderator
Ok, I've just implemented a possible solution.  I've separated all music files into their own subdomain, and all other downloadables into their own subdomain.
I've noticed in the web access logs that some people appear to be using downloaders which open multiple simulatenous streams (like fresh download?), which really swamp the website when they're downloading. Now, when that happens it'll only swamp the downloads or music subdomain, and the forums should keep running just fine. I hope!
Let me know if it's better/same/worse.
-John
-John
- John Cooper
 - Moderator
Since I made this change, I haven't seen any problems.   Am I just getting lucky or is it really better?  Sounds like a few of you are still having problems?  Are you still?  Is everyone else ok?
I can see in the logs that bandwidth usage for the main site has been cut in half, good thing! There is still the possibility for the occasional bandwidth hog, as there are still some mp3's that need to get moved from the main site into the music.planetz.com subdomain.
Let me know!
-John
Let me know!
-John
- John Cooper
 - Moderator
