Mono vs stereo mixing
fra77x
Post by fra77x »
Hello to all. I 've read in the latest Computer Music that a lot of producers uses mono than stereo in most cases.
What do you use?
marcuspocus
Post by marcuspocus »
Mono, if possible, cause imaging after is easier. For example, a piano sampled with 2 mics (stereo), create phasing problems, and imaging is very very hard afterward...
algorhythm
Post by algorhythm »
stereo - yo'
music is noise thru time AND space - surround sound is even cooler.
I like phasing :wink:
marcuspocus
Well, it depends! Obviously, if you like phasing :razz:
But it is true that i mix in stereo afterward everything, and even tried the small 'AC-3' tutorial found here in planetZ using the surround mixer to record 6 wavs file and later encode it in AC3, then created a audio cd with AC3 audio on it. I can read it back using my dvd player, pretty cool! But really hard to create a real mix with only 2 monitors. Not really ideal. Anyway, at least i know this work :grin: !
sandrob
Post by sandrob »
:eek:
kensuguro
Post by kensuguro »
phasing's cool. Just the right amount of it creates a roomy feel. Something that "professionally" recorded material often lack. But of course, you should stay away from massive cancellation.. (duh)
good argument for starting with (mostly) mono tracks......
<font size=-1>[ This Message was edited by: garyb on 2002-10-17 13:11 ]</font>
