can you recommend pulsar 3.01 with winXP ???
helldriver
Post by helldriver »
I´m running win98 with Pulsar 3.01 with no problems and want go with winXP in the near future.
i don´t wanna upgrade to sfp yet (because of my projects). maybe I wanna install them together pulsar3.01 + sfp3.1c.
my question is:
is 3.01 running stable and without problems under winXP????
Spirit
Post by Spirit »
Moving from 98 to XPhome on 3.01 was the biggest stability improvement I've ever had with Pulsar.
Moving from 3.01 to 3.1 was the next best :wink:. Things just "feel" solid now - or maybe I've just got over the jitters I use to have from getting base.dll crashes ...
Happily I haven't seen one of those in a loooooong time now.
braincell
Post by braincell »
It at least won't hurt provided you have a powerful enough computer.
helldriver
is xp eating up more resources than win98se especially focused on cpu?
i have a p3 with 933mhz and 512mb ram.
remove all non essential services and use 3.1c.it's good........
Here's how little RAM XP can be set up to use:
Lotuz
Post by Lotuz »
I had some problems with the Pulsar 3.0 software and Cubase SX (crackle when recording MIDI and/or audio) on WinXP, but SFP 3.1c fixed it. And I can set the latency than before. :smile:
helldriver
lotuz, did you have the problems with 3.01a or was it 3.0
<font size=-1>[ This Message was edited by: helldriver on 2002-10-12 21:03 ]</font>
Lotuz
Post by Lotuz »
I'm not sure which version, but they both use the same drivers. So I think both versions will have the same problem with SX.
