let the bass live.. man.. (reverb talk)
kensuguro
Post by kensuguro »
Recently I've been working a lot by just passing a 2 mix (finalmix) through a reverb. Just to make the quick jobs even quicker. So I do it initially with my Yamaha DSP Factory just to get a feel of how it would sound. And then, after I record the dry signal, I reverb it again with Masterverb. (thinking it'll yield better results) But surprisingly, Masterverb ain't good at all with mixed signals. Why? Simply because the response is too flat. The only colorization I can do is either in the hipass/lopass filter section, or with the Hidamp control. Either way, I can only cut away from the signal, and not have anything boosted.
The effect I'm looking for is like this
See the knobs "HI.RATIO" and "LO.RATIO"? Hi goes from 0-1.0. So basically, you can only damp the HI's. But the LO.RATIO knob goes from 0-2.4, meaning you can actually boost it in someway (so it reverbs more). This seems to be a little more than just pre EQ. And somehow, this knob saves me alot of trouble.
By the way, the gate section on the right does some neat tricks. :smile:
Usually, to get a sort of similar effect with Masterverb, I have to load in another Masterverb just for the lows, and mix that in. But, that's a bit different as you'd imagine, from the Yamaha reverb. It's not about the mix of signals, but more about having different frequency zones "living" longer within the reverb tail. (was that clear?)
Well, the easy answer is... use the goddam Yamaha reverb. But the tech freak in me says there's gotta be a way to do it in Pulsar.. I checked all the reverb devices.. Masterverb Pro, Goldverb, and the Timeworks one, but they all seem to be working under a similar format. It's always just a hipass/lopass, damp combo. Goldverb does have a way to boost signals.. but then, it's too DSP heavy and the newest version doesn't work in SFP.. But I haven't checked Paul Tanti's line.. how do they work?
Well it's the all classical reverb comparison.. but always fun nonetheless. The topic this time would be "colorization". (in contrast to previous "quality" related talks)
<font size=-1>[ This Message was edited by: kensuguro on 2002-10-10 07:16 ]</font>
visilia
Post by visilia »
It's not a shelving filter, but the Timeworks Reverb has a one band parametric EQ. I think you can have similar results as the Yamaha reverb when using this with a low Q setting.
edit:
Or are these filters of the Yamaha reverb in the feedback chain of the reverb (like a reverb damping filter)? If this is the case, The EQ of the Timeworks reverb isn't what you want, because that one is post reverb.
cheers,
vincent
<font size=-1>[ This Message was edited by: visilia on 2002-10-10 08:29 ]</font>
ChrisWerner
Post by ChrisWerner »
Strange, isn´t it ? The most low cost native VST reverbs have more worth for their money than our professional creamware gear.
<font size=-1>[ This Message was edited by: ChrisWerner on 2002-10-10 08:47 ]</font>
visilia
Post by visilia »
Well, I have heard good things about Reverb.it from Silverspike, but unfortunately it lacks Early Reflections, which is a very important part of a reverb for me. Do you care to tell what these low cost native reverbs are you're refering to?
cheers,
vincent
ChrisWerner
Hi visilia,
I bought myself the WaveArts Surround DX, it have a superb sound and all parameters you need. 89.95$ . The MasterVerb from WaveArts costs more but has a ultimate GUI,a 2D window where you can setup your room bye small mouse movements. http://www.wavearts.com
Look at Spinaudio.com Room Verb full "colorizeable" 74€ or the whole bundle for 195$.
For short room reverbs ,maybe on drums I use the free Room Machine844.
Of course you can say ,eh 90$ is not low cost, but compare it with the Renaisance Reverb 300$ or CW´s Masterverb Pro 198€.
I don´t say that CW products are nothing worth but there is more movement and improvisation in VST effects.
Look around.
Cheers
kensuguro
Post by kensuguro »
visilia, I think the filter I'm referring to happens to be within the feedback chain. (hence the biased gain) Doesn't seem to be hard thing to do... well, maybe a native solution would be quick.. but then what the heck, I might as well use the Yamaha I've got right now.
sandrob
Post by sandrob »
thanks for info, chris, :smile:
new wavearts sounds fantastic to me :smile:
kensuguro, try 30days full-working demo! :smile:
try trackplug too!? :smile:
<font size=-2>got my mojo working, but it just won't work on you</font>
<font size=-1>[ This Message was edited by: sandrob on 2002-10-10 11:00 ]</font>
why not insert an eq b4 or after the 'verb?or if you really want to be tricky,you could return the verb to a channel and use the aux to bus a portion of the original signal to the eq...
or just be sensible and return the 'verb to a channel and eq with the channel eq...
<font size=-1>[ This Message was edited by: garyb on 2002-10-10 13:07 ]</font>
ChrisWerner
:smile: ... think modular..
EarlyFirst
Post by EarlyFirst »
They have the shelving filters but the demo's do not allow you to play with them
(sorry)
kensuguro
Post by kensuguro »
coming to think of it, I still wonder why I don't have one of your reverbs Paul... I should get one. I just never know when you're going to be out with a newer, better one! :lol:
thermos
Post by thermos »
if i understood you correctly??
My suggestion will be to split the signal into "freq areas" hi, mid, low and then feed each area into its own verb and mix them together again.
i think celmo has a frequenze splitter.
if you try this, then try to use differnt verbs for different signals that could be intersting, throw in a delay and delay either the hi or mid signal with a few ms. that could make some nice ambience aswell.
I think subtle is the key word here.
thermos
ChrisWerner
http://www.planetz.com/Pulsar/files/mod ... plitVU.mdl
It was Joeka with a great freq.spliter..
:smile:
sandrob
Post by sandrob »
i need m-s spliter?
need,neED,NEED!!!
Immanuel
Post by Immanuel »
:smile:
Ehh, that link makes a lot of strange symbols :/
kensuguro
Post by kensuguro »
ya need to shift-click, or save link target as file.
it's a mod2 patch.
Michu
Post by Michu »
Ken
did you look into native Silverspike and Ultrafunk verbs?
Sunshine
Post by Sunshine »
Hmm Kenseguru, when a reverb doesn´t work on a final mix, it shouldn´t be the Eq-ing that makes that reverb sit right. It´s probably the reverb itself, that is not suitable for the task. When putting a reverb over your final mix, you do that because it lacks a certain continuity in feel (too many dry and wet differences). By adding an overall reverb you gather all the elements that are present in a mix and put them into one single ambience. But a strongly Eq`ed reverb will change the spectral balance of the mix and shouldn´t be used in that case. The algo should be transparent as possible whithout the slightest coloration. M3000 is often used in that case because of its "no sound". I´ve heard in different forums that there are some plugs availible that do fairly good job in that regard.
Regards,
Bernhard
kensuguro
Post by kensuguro »
well, yeah, you're definitely right. Just that the situation I was facing was kind of different... as in, I did everything dry, and just needed to push it through a reverb. The job was a quicky, so I didn't want to bother with balancing dry/wet for each channel... And whatever it was, the Yamaha reverb did a fine job at it. So I was actually using the reverb to colorize the mix.. (or should I say I tried to fix the mix within the reverb) Not a good way, but it's just quick. Thanx for y'all's tips tho!
