I would like to know how people are using the automation with nuendo ? I use the pulsar mixer so I would like to know if there is another way than to use assigned CC in the nuendo midi window . I would like to see the waveform "and" the automation curve . for now I have to open the midi track window etc ..
thanks
nuendo automation
spiderman
ok , ok ...
it seems nobody use the automation with nuendo, well ! to answer to myself i think there is no other way than by using a midi track with cc . it's a little bit boring because then you don't have the cc curve with the wave form . samplitude is far far better with pulsar 'cause for each audio track you have a dozen of cc at your disposal which can be set for pulsar device/mixer , and the curves are drawn on the wave form just like regular curves like volume , pan etc ..
