I've been experimenting with some reverb theories and i need to modulate the delay times with a LFO but i can't get it to work.
I used the tempo delay. If i connect a const. freq i can set the delay times with it and i can set them at shorter times. Less than 45 ms that you can set manually. But when i try to modulate it it does'nt work.
I tried with OSC, FM operator and in desperation mixing fixed freq. with a LFO. Of course that did'nt work.
So basically i am lost.
And i did'nt seem to get the lopass filter in the delay module to work either. That probablly only works with internal feedback and i need external feedback. So it is not a biggie.
I'll post it if i get something useful.
In the meantime i've been doing it in Reaktor with some good results. It could be a nice alternative to the other reverbs. You can never have to many, can you?
BTW i have Modular II. Have'nt upgraded to Mod II yet but i will.
Modulating delay times ?
Music Manic
No. That really isn't an option.
I need at least 4 LFO:s modulating delay times and i really don't wan't to do it that way.
The thought crossed my mind though.
There must be another way to do it.
Mixing 2 modulators. How hard can it be.
<font size=-1>[ This Message was edited by: jupiter8 on 2002-09-29 16:42 ]</font>
There is a modulating delay in Mod 2 as well.
I can set the delay time using a fixed frq. module.
But there must be a way to modulate the delay times.
When i try with an osc. it does'nt work.
If it did i could just modulate the osc. frq with a LFO but so far the only thing that works is the fixed freq. module.
I'll do some more experimenting today so we'll see.
Problem solved.
I connected the const. freq. module to a pitch modifier which i modulate with a LFO.
I got a "division by zero" error message.
That's why it took so long to figure out the solution.
It works though.
But it crackles when i modulate the delay time. As to be expected you might say. Yes. But it does'nt when i do the same in Reaktor.
Anyone got a solution for that?
It works though.
