Latency in XTC-Mode (not a basic question)
Dolphin
Post by Dolphin »
There is something strange about the well known latency when inserting Pulsar-effects in XTC-mode. Usually you must insert the XTC Delay M/S into every channel as soon as you have inserted only one effect in another channel. E. g. you insert a chorus on channel one, you will have to insert the XTC Delay M/S into any other channel to compensate the latency of channel one.
I am using SX and - what a surprise - the latency sometimes occurs (e. g. when I use the Compressor) and sometimes it does not occur (e. g. when I use the Chorus). And even more surprising is, that I must (!) insert the XTC Delay in any channel that plays a Pulsar Synth - that means, that this synth is "too fast" or sounds "earlier" than a VST-Synth or audio track. This is unexplainable, right?
I mean, this is not really annoying, as I definitively save time because I do not have to insert the XTC Delay into every damn channel. But I really would like to understand it ...
Any idea?
Uwe
<font size=-1>[ This Message was edited by: Dolphin on 2002-09-24 04:16 ]</font>
<font size=-1>[ This Message was edited by: Dolphin on 2002-09-24 04:17 ]</font>
spiderman
Post by spiderman »
hi ,
no answers here ..
I've got the same trouble in nuendo 1.53 .
with two identical tracks with the same FX (vinco and peq4) I've got an awful sound . strange because the latency should be the same ??? without the fx the sound is perfect ....
that seems to have something to do with the limits of vst.i have had a similar problem in logic with some native vst plugs....
Steve-o
Post by Steve-o »
The same here...
your sequencer can be adjusted to play that track earlier to compensate.
