Don´t tell me, that anyboady really hadn´t this problem with
Peter Cherry
Post by Peter Cherry »
I think, that many of you had to met this MIDI problem with Cubase SX, because in Cubase 5 everything is working ok (on the same system).
When I have several recorded MIDI tracks routed to Pulsar instruments (not to VST instruments) and I want to for example one of them play/record live through MIDI keyboard, everytime I touch the keyboard, other MIDI Pulsar instruments get quiet. But when I replay what I recorded live, all other Pulsar devices are playing good.
Please, help me, because how can I record other new tracks to former recorded when I can´t hear them during recording ?
Thanks a lot in advance
Peter Cherry
alfonso
Post by alfonso »
i'm not having this behaviour of sx...
i don't know what to say, except for the suggestion to post also all your sistem specs. and all the settings of all devices (midi ports etc...)in sx, so maybe something can be found there that explains the strange thing.....
i hope you solve it.
check also cubase forums.
ciao.
Steve-o
Post by Steve-o »
Never saw that with SX 1.03 or Nuendo 1.61.
Peter Cherry
Even one thing, when I hold one key and play the others, everything plays.
alfonso
Post by alfonso »
post your specs, sw version, midi ports enabled, master keyboard tx channels etc....
nobody has crystal ball.....
...and every one has a different setup.
I never experienced it either.
one hint: The amount of SeqDest/Source in your project, as specified in Device Manager.
Peter Cherry
So my setup is:
Standart PC with WIN XP Proffesional ENG ver,
Creamware Pulsar I with SW 3.1a
Roland Alpha Juno 2 as masterkeyboard
Now I´m not at my computer, so I can´t tell you what I have set up in Device manager, but in Pulsar manager, Seq Dest shows 1 for chanel and it can´t be changed.
Peter
<font size=-1>[ This Message was edited by: Peter Cherry on 2002-09-20 04:12 ]</font>
Peter Cherry
And to understand me exactly:
I´m using Cubase SX and with former Cubase 5 on the same system I never had this problem before. I hear instrument that I´m recording, but I don´t hear others (external Pulsar)insruments routed by virtual MIDI from Cubase to Pulsar (I hear only internal VST instruments). And when I stop touching MIDI keyboard, all external instruments will start play again...and when I start touching keyboard again, all extarnal instruments will silent.
alfonso
Post by alfonso »
very strange...do you have both sx and vst currently installed on the same machine?
and in this case, what happens if you close sx and open vst with the same pulsar project? if vst works normally, you should maybe reinstall sx...
i know also that there was an issue with sx showing multiple midi ports...and some of them must be disabled in device settings, as they double data..(i never had this on my system, but others had).
you know, if pulsar synths are loaded they usually have one voice polyphony, and if they receive doubled midi notes they could stop playing.
do you have each pulsar inst. on a different midi channel? they usually are loaded in omni mode, in that way they receive from all channels....
Peter Cherry
Thanks Alfonso for your replay, but I´m not just stranger in music SW&HW, so things like low polyphony of instruments, different MIDI chanels and whatever are for beginners. It´s not this problem.
Yes, I tried to run old Cubase with the same project, everything ran well. So problem seems to be in Cubase SX, I tried SX beta before and problem was the same + multiple MIDI ports. So reinstalling of Cubase also doesn´t help.
Peter Cherry
New fact:
I tried to conect from SEQVENCER MIDI SOURCE only STS400 and into STS I loaded 2 instruments (the fisrt on midi channel 1 and the second on midi channel 2). Polyphony was set up to 10 voices (for example).
But problem is the same. When Cubase SX is replaying part for instrument on chanel 1 and I´m recording with instruments on channel 2 everytime I touch the MIDI keyboard, the other instrument gets silent. But after recording, when Cubase is replying both parts together, both ones are playing ok.
kimgr
Post by kimgr »
I just tested SX on my setup, and the midi is just fine...
What midi interface are you using ???
Kim.
Dolphin
Post by Dolphin »
Hi Peter,
do you use ASIO2 drivers? As far as I rembember, ASIO1 drivers cannot work in full-duplex-mode, that means, you cannot listen while you record something else (just an idea ... might be wrong). Anyway, I use SX in XTC-mode or OS-mode without any problem. So there must (!) be a solution!
Good luck,
Uwe
Peter Cherry
To Kimgr: I´m using Roland Alpha Juno 2 connected directly to Pulsar I.
To Dolphin: Man, we are talking about MIDI, you know, about MIDI not AUDIO. But thanks for your time.
Peter
slenderflame
Post by slenderflame »
Got monitor turned off on all the other channels? I remember that I used to have the same problem. Solved it somehow. But I can't exactly remember how.
kimgr
Post by kimgr »
Peter, you need to get a real midi-interface.
The one on the Pulsar card is worse than those on cheap SoundBlasters...
Kim.
(P.S. Don't kill the messenger !)
Peter Cherry
To Kimgr: Yes, I think I´ll have to kill the messenger, because you want to say, that I must buy new MIDI hardware, when I install new version of o SW ? You are a dealer, aren´t you :smile:))))
SW is only SW and when my MIDI Pulsar Interface was very good for my requirements before, it can´t get worse itself with a new version of the same SW.
Please, help me somenody. I don´t want to return to Cubase 5, because new SX I like.
<font size=-1>[ This Message was edited by: Peter Cherry on 2002-09-26 02:57 ]</font>
there must be some setting in sx that's connected to midi record/playback.i don't have this problem in logic.(man,you must have tried every menu by now........still, it HAS to be a setting if it's not a corrupt installation..)
Peter Cherry
Yes, I also thing it could be in any setting, but where, I looked through everything possible...
slenderflame
This does definatly not have to do with Creamware in!!! Since I used to have the same problem and now it's solved. It was some "stupid" thing like having the channnel you play on set to "omni" or something like that. I just can't remember. Sorry. You seem to surpress the other channels by "playing" them.
