CONTEST [brainstorming session]
algorhythm
Post by algorhythm »
SEE ANNOUNCEMENTS FORUM
<font size=-1>[ This Message was edited by: algorhythm on 2002-09-15 12:12 ]</font>
bosone
Post by bosone »
good idea!
i only don't understan why you mentioned samplers...
if i can add my 2 cents:
- track should be composed used only 1 patch per synth (no "sound changes" during the track - you select a sound for inferno and bluesynth and use only those. only modulations are permitted)
- a polyphony limit for those synths should be set, so that people with 45 DSP are not advantaged! :grin:
- you will have to post also the presets you used in the three synths, just to add something to the community "preset collection"!
Nice idea, the 3 synths only. Good you suggested the Hummelized/Mehdized versions for Inferno and Bluesynth too, cos Inferno3 is in SynthPack2.
I'd suggest a drum machine too, one everybody can use. We could choose one drumkit from the CW cd with a sampler or a machine like the one from Wavelength. Or do we make drumsounds with the synths? Can also be done.
[edit] oops! i totally missed your EDS8i in the list.
If we'd only use DSP devices (and seq/recorder ofcourse) the song could be a real representative demo for CW. And external gear I'd reduce to a minimum too, like with a hardware sampler you can make any sound out of the 3 synths.
I saw a contest once where you could only use white noise as sound source. Have a look :smile:
http://www.geocities.com/SunsetStrip/St ... lenge.html
<font size=-1>[ This Message was edited by: at0mic on 2002-09-13 12:07 ]</font>
<font size=-1>[ This Message was edited by: at0mic on 2002-09-13 14:39 ]</font>
algorhythm
That is why I put the EDS8 as the third synth - it is the free drum synth from CW - but your right, plasma is donation-ware now. How about we use the Plasma instead of the EDS8i??? (that is the real name, I just checked CW)
algorhythm
I knew someone would say this. well, if people want this, it might be better, and will make it a little more *restrictive*, which is a good thing usually. . .
algorhythm
to bosone - I disagree about the one-patch only. It is a matter of degree, say, through CC# tweaking, you modify ALL the parameters such that you have basically changed presets . . . I agree about the preset uploading; always a good thing!
Regarding samplers: Um, I sample synths ALL THE TIME while making music. I almost never have several synths running throughout the whole track. I just don't work that way, and I am sure that others are the same. Same with polyphony: I don't think that 45-chip people have an absolute advantage. Surely it helps, but it doesn't make or break anything. I used to do some good work on a Pentium I 166mhz alone!
bosone
Post by bosone »
yes, you are right. i was thinking about my statement, and i must say it's not a great idea. so, patch change allowed :smile:
marcuspocus
Post by marcuspocus »
Yesterday i was trying with devices mentioned here, how woulkd that sound... And i must say, that it was the first time i tried the EDS8i... Arrrrrgggg! Never tried a drumsynth sounding SO BAD!!!! Arrrrggghhh! :smile: Horrible!
Would it be possible to use sample player + GM Drum 1 from best services CD that come with Pulsar?
algorhythm
check out http://www.track0.com/wavelength - and make a donation too!
I strongly think that we shouldn't use samples that weren't created WITH Pulsar - if we agree to use the plasma, then this would fulfill this. And I think atomic is right - only Pulsar effects should be used. Only use other apps for sequencing / hard disk recording / editing.
<font size=-1>[ This Message was edited by: algorhythm on 2002-09-14 12:57 ]</font>
kensuguro
Post by kensuguro »
Heck, I didn't even know Plasma was on the shareware list. Definitely will give it a try. It's GOTTA be better than EDS8 whatever, I can make a better one even in Mod2!
Anyway, here are my thoughts:
* Only the 3 mensioned synths (plasma takes over eds8)
* Sampling is OK, unless you do a 200 part orchestration. (drums, effects is OK) But I still do think we should keep away from totally changing the image of what a plain Pulsar II (or whatever card you have) can do, in terms of real time synthesis. But of course then, Mod2 would be at a definite disadvantage so... Oh well, this line is hard to draw. More discussion to be had in this area.
* Polyphony shouldn't be restricted, because you can prioritize. Say, you might have a 2 voice part, so that you can have 6 in the other. So it's kind of hard to draw the line. I'd still say that the polyphony limit should be the max that upir DSP allows. (even by using the STS series)
* External hardware: Well, none for me atleast. It's cool to stay within the Pulsar boundary.
So anyway, let's see where this goes. It sounds very interesting anyway though! The idea of restrictions just turns me on. :lol:
algorhythm
OK - for final approval:
"Cream of the Crop Contest:"
~ 3 devices: Inferno (Creamware and Hummel Wavelength versions), Blue Synth (Creamware, Hummel, and Medhi versions), and Plasma (donation-ware from Hummel).
~Pulsar-only effects; no VST, hardware, etc.
~Samplers are OK, but sound-sources only from the three devices [and as Ken says, stay true to the spirit of 'pulsar synthesis' - no over-orchestration or rediculious sample-mangling]
~Use whatever MIDI/Audio sequencer/recorder you want
~ Less than 5 minutes in length (roughly, if it is a little longer don't sweat it), 128KB mp3
~ Due by Nov. 1st
~ Post to PlanetZ music area with "Cream of the Crop Contest: X [where X = title of your work]"
~ Prize = respect from your peers
___________
Everyone think that these rules are OK?
oh, and if you're posts are greater than 100, you are expected to participate! :wink:
<font size=-1>[ This Message was edited by: algorhythm on 2002-09-14 17:00 ]</font>
borg
Post by borg »
:smile:
joel: your hydrocarb... mail address, is it still in use?
I'm in
algorhythm
Contest has been announced in the announcements forum, oddly enough! :wink:
wayne
Post by wayne »
Plasma seems to use 2 dsps on it's own - us with 4 dsp or less can't load these 3 synths simultaneously! :sad:
algorhythm
. . . and that is when you would sample your drum sounds from the plasma . . .
wayne
Post by wayne »
ah, very clever :smile:
if this is intended to have any positive effect on the reputation of Creamware gear as a production system, you can't go with those first generation devices.
I've tried the same as Marcus (just for curiosity) - nope, horrible. There isn't even portamento or smooth filter sweeping present.
My 2 cents for the rules would be any 2 synths and a drumbox (but not more than 3 devices) which are available for free or as shareware.
This would also result in a broader range of sounds, which is certainly more fun to listen and a better representation as well.
marcuspocus
I agree, no portamento possible with STS, but filter sweeping, you can get it from sts, or another sfp effects if sts isn't good enough. Those are not restricted in the contest.
algorhythm
Tom - have you tried the wavelength versions? they are very smooth. about creamware's reputation: that isn't really the point of this contest, but I am sure that great tracks will result with the synth set we have chosen.
However, I wouldn't mind bi-monthly contests with different rules and limitations. The idea for this one, that has been kicked around in the past, was to use specific synths and see what we can come up within that framework. Since this contest is already underway, how about you frame the next ruleset for the next contest to be tentatively ending on Jan. 1st 2003? I do like your idea, but don't think it is 'better' than the current one, or other possible ones, just different. . . . I think I am going to make an electro track using mostly the wavelength inferno. hehehe
