Multiple i/o plates for one Pulsar
spoimala
- at0m
I thought only one IO board per DSP card could be installed, just cos there's no more physical connection on the card to put the IO board on.
I'd be happy to hear I'm wrong.
spoimala
- at0m
subhuman
This is not possible with the cards (from everything I know about them) - only the Luna can have "2 plates" (I put 2 plates in quotes, as you can't choose either plate: you can only add on the Luna Expansion plate).
Best bet if you need both I/O plates is to get another Pulsar2 with the plate you want -- 12 DSPs, (6 for each Pulsar2), and two I/O plates...
You can however, add a Sync Plate ... there is a separate connector for that on P1/P2/Scopes
<font size=-1>[ This Message was edited by: subhuman on 2002-09-03 14:34 ]</font>
