I'd like to see sequencers and LFO's to recognise Start/Stop/Continue/Song Select.
Imagine. You like your Phaser LFO to be at it's most positive depth right at the break in your song, together with the filtersweep on another track. How do you create a phase offset between the phaser's and ie. pitch LFO? How can I use a square LFO to create a pattern inside the song? The different LFO's in a project, even if set to same LFO rate, don't run in phase. When do those LFO's begin at O° phase? When you load them first?
How about sequencers? I know I should be moderate with these, cos they're quite young on our platform.
http://www.borg.com/~jglatt/tech/midispec.htm
the bottom of the L/H site menu, Midi Start/stop/Continue/Song Select explanation, looked quite interesting. I posted some about sync in here.
Sweet Midi Sync
- at0m
King of Snake
- at0m
I'll explain a little more. In Cubase SX for example, there's a Step Seq. Controlled Filter, which actually runs the steps like they were written in the sequencer. I've thrown a guitar thru the filter, and I want the sweep to go in a certain pattern in respect to the guitar and the rest of the song. This is a very usefull option. Start/Stop/Continue should be recognised by the LFO's. Would be Super.
