<a name="planetz-file"></a><a href="http://www.track0.com/wavelength/trans.zip"><img src="/forums/images/file_icon.gif" border="0" alt=" File"> File</a><BR> <a name="planetz-file"></a><a href="http://www.track0.com/wavelength/transf ... .htm"><img src="/forums/images/notes_icon.gif" border="0" alt=" Notes"> Notes</a><BR> <a name="planetz-tag"></a>Price ($USD): 20<BR> <a name="planetz-tag"></a>Type: Effect<BR> _____________________________________<BR><BR> transfusion filterbank
note: all LFOs and envelope gates are MIDI triggered, so remember to plug in your MIDI source to the transfusion's MIDI-in.
specs:
- stereo filterbank, stereo ringmodulator, stereo 5-second delay, stereo distortion + crusher (grain texturizer) (all true stereo signal-path integrity)
- stereo filterbank: switchable multi-mode lowpass, highpass, bandpass (2-pole/ 4-pole, switchable); custom hummel 'hyperfilter' lowpass; band-reject; tube resonator
- 2 filter modes: singular/ parallel
- parallel mode allows all filters to process audio at the same time, blending the filtered signals and allowing each filter level to be mixed with the others
- the cutoff and resonance knobs control all filters simultaneously, in parallel mode, allowing for unique notch filter variations and beyond!
- cutoff frequency can be modulated by: velocity, aftertouch, LFO (with its own dedicated frequency LFO), envelope and key follower--all at the same time!
- feedback level of filter(s) can be adjusted
- stereo ringmodulator features a dedicated multi-mode control oscillator (sine, tri, sawup/ down, square [with pulsewidth], noise [tuned, white, pink])
- seperate left and right wet/dry mix controls for ringmod
- switchable keyboard oscillator control/ sweepable oscillator frequency knob (with dedicated frequency LFO)
- stereo delay with up to 5-seconds of delay time per side
- there are also control parameters for input level, overall volume level, distortion, crusher, panning, pre-filter mix and cross-feedback level!
- true bypass of all features is included, as well as on/off switches for individual sections
FEATURES...
- a true-stereo filterbank, with all MIDI-controllable knobs
- use it piggy-back style, after your old synths to create all new sounds! just connect the Pulsar MIDI Source to the transfusion's MIDI input (like you did with your synth), put the old synths audio out into the transfusion's inputs and connect the outputs of the filterbank to your destination of choice! brand new synthesizer!
- transfusion is capable of designing harmonically-rich distortions; metallic ringmod timbres; complex, linear, spatial soundscapes, your creativity is the only limit!
- use the transfusion to tweak your final stereo mixes! make subtle timbre shifts, or radical mutations of the original tracks!
- whether you want to make a slight shift in your sound, or mangle it beyond recognition, the transfusion will get you there!
<BR><BR><a name="planetz-fileimage"></a><IMG SRC="http://www.track0.com/wavelength/transscreen.jpg" BORDER="0">
hummel transfusion filterbank
wavelength
