Masterverb (by Claas)
Guest
Guest
Subject: EarlyFirst and Timeworks...
There is a new EarlyFirst reverb that I have been beta testing for Paul, and it rules. I think it will be called the "PT Pro Verb" and you should check it out. It's easily on the same level as the Timeworks stuff, but with a different character.
If you haven't already, check out the Sonic Timeworks stuff. The Timeworks 4080L is my main reverb, it is easily better than a Lexicon MPX100
The PT Pro Verb is really awesome on drums...
Guest
Guest
Guest
Guest
Subject: hi ingo (2nd question!)!;)
hi ingo,
is there something know about midinotes hanging up in systems while using the direct connection from pulsarmidi source to the instruments? since i have begun to work on 2 seperate systems while pulsar is one system for its own i have this problems on the synths - most time on channel 1!
thanx
t.
hi ingo,
thanx
t.
