I have a Luna 2 and am running Sonar 2 (with which I am very happy). I can manage to add effects to the sequencer/wave out easily enough, so its on the whole song, but is it possible to seperate out the different audio tracks in my sequencer (into scope?) so I can add effects individually?
I know this is a bit of a newbiew question, but its something I really want to know since I use a lot of audio.
Effects
algorhythm
you will have to set up busses in sonar. then, route certain (or single) tracks to busses. these busses should then be routed to the audio driver, which is wave for sonar I believe. These then correspond to the "wave source" modules in SFP. You will have to have as many driver modules as different outputs you want in sonar. Then, you can apply effects individually to each of the separated outputs. It would be best to use a mixer in SFP to set the levels, insert fx, and route to your analog outs.
hope that helps.
hope that helps.
