..Is a very musical, intuitive and generally brilliant loop mode that seems to have vanished from samplers of later years. For those who've never heard of it, an alternating loop plays forward, then backwards, as opposed to the standard forwards only. It does'nt require the cumbersome searching for loop points or any destructive editing of a sample. Roland, Emu(III) and Ensoniq samplers have featured it in the past. The only drawback as far as I know is that it requires a bit more processing power than forwards-only looping.
Personally I have no problem with that. I'll gladly trade a few voices for the creative aspects, the boring work it saves and the quality of results this mode offers. I'd definitely welcome a per zone/sample switch for this.
Edit: In the sts samplers, that is..
<font size=-1>[ This Message was edited by: John Henric on 2002-07-17 21:25 ]</font>
						Alternate loop
				John Henric
				algorhythm
check out phatmatik pro - http://www.bitshiftaudio.com - it does forward-backwards OR backwards-forwards -  I use it religously now
  -  check my latest track in the music area for a sampling of that beast.
now what i REALLY want is CC# controllable loop start/end points
				John Henric
I just found out.. NI Kontakt does it but I have'nt tried it yet.
Edit: I goofed around with it the other day and unfortunately it seems NI yet have a few lessons to complete in the wave driving school. Kontakt is a brilliant smapler but the alternate loop does not make a clean turn, it clicks when the loop reverses. Careful editing brings it down though, but it's still there. As long as the sample is clean and not too exposed or effected in the mix I think it's useful. I hope they'll solve the click in an update. Gah, where have I heard this before..
<font size=-1>[ This Message was edited by: John Henric on 2002-08-07 10:34 ]</font>
I checked out and wauw that's something, Algoridm.On 2002-07-17 21:00, algorhythm wrote:
So you're using it already, how easy is it in practice?
Gonne check you're upload now.
The Akai S5000 does fwd/bckwd and all you want, but it has no realtime control for it.  Solution might be to use different programs w same sample?  How about the STS-5k?
				John Henric
				CreepJoint
				John Henric
Yes, and I've tried it a couple of times in soundforge. I must be missing something, or at least I hope I do
 because anyway I do it, the reverse point is obvious, there's always a little snap, crackle or pop. Try it yourself -> copy, paste to new, reverse, switch to the original window, select all and then do a mix 'at end of selection'. Result: Zswaaaoouuu-ktick-uuuooaa.. The edit looks fine in the waveform window however. Any digi guru who knows what's going on? I'm puzzled, as 1. It's a piece of cake for some museal hardware samplers 2. Theoretically it's a simple (and elegant) thing.
Que?
I'm glad to see there's some interest for this. To the sampler newbies: this *is* really cool. You can get so many weird and wonderful sounds out of 'impossible' material. If you come across an old roland sampler (s-550/330, w-30) or an ensoniq eps model, try it out. itouttuottiitouttuo...
<font size=-1>[ This Message was edited by: John Henric on 2002-08-13 13:50 ]</font>
						Que?
