Heres something for people who make synths.
Usually i have had a poly LFO so this has not come up.
When i use a mono LFO to control a poly filter or whatever, it will only modulate 1 of the notes played, i realise it will not retrigger or anything, but the other notes do not even get modulated.
the modulator in this case is actually an envelope follower which is set to 1 voice.
it seems i need something like the poly mix but the other way around.
what am i missing here? i do not remember this problem before.
Also is putting a "dyn voices of parent" set to 1 the same as "load single" all the sub modules in a module?
